panhead cam grear covers
  • esquire
    • Sep 2010
    • 49
    Ok I have been looking for a cam gear cover and do not know what fits what
    I have looked on e-bay and found some , I know I need a 4 fin for a 62 pan but have been told there is a defferance in the years , I would like to know from the 48 to the 64 , i do know the 65 and on up . any help ? thank you
    Esquire
  • Steve Little
    • Apr 2008
    • 915
    Hi.
    The 4 fins on the 61-62 cam cover look like the 63-64 outside oil cover. These 2 covers are different to the earlier four fin covers.
    The lowest fin on these two covers is only 3 inches and does not reach the front edge of the cover like the earlier 4 fin covers.
    There is no mention of this 61-62 cover in the How To Restore book.
    If you need a picture let me know.
    Regards Steve
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    • esquire
      • Sep 2010
      • 49
      You are right on the How to restore book ,I have this book .
      I do know the 63 and 64 had the outside oiler but did not know
      about the 61,62 and the ealier ones had a longer fin on the bottom
      fin. And yes if you could send pictures it would help me when I go to
      buy one. Thank you so much for you help . ESQUIRE
        Here is a 1962.
        • bmh
          • Feb 2007
          • 901
          55 and earlier covers are different in the area at the top of the oil pump. In the pic Chris posted you see a tubular portion running upward at about 50 degrees. This is not present on the early covers and the edge of the crank case is visible there.
          Brian Howard AMCA#5866
          • Steve Little
            • Apr 2008
            • 915
            Esquire. I have a taken a picture of the 4 types of 4 rib covers.
            In the past I have found myself inadequate in task of posting pictures on the forum.
            If you send me a email I can send it to you.
            Or I can send it to one of the more geekish.... err no.... strike that. That should read tech heads of the forum.
            Regards Steve
            Steve Little
            Australia.
            AMCA member 1950
            • esquire
              • Sep 2010
              • 49
              thank you all for all the help on this and steve this is my e-mail : glethms@aol.com
              thanks again every one Esquire
              • BigLakeBob
                • 2768
                Steve, Can you send me the pics also. biglaketool@embarqmail.com Thanks Bob#6738
                Bob Rice #6738
                • cdndewey
                  • Jan 2005
                  • 438
                  While you're at it I would appreciate a look also. dewey@telus.net
                  Steve
                    This is a weird subject. Here’s a pic of an original paint 60 at Oley 08 and the cover on it sure looks like the one on the 62 Chris posted. Bob L
                    • Steve Little
                      • Apr 2008
                      • 915
                      Hi Bob. Nothing wierd... your right. I researched this subject a few years ago and wrote on each cover what years I found they were fitted to. I had written on that perticular cover 60 -62. Better strike what I wrote in my first post. I was working from memory ..... which is not my best medium these days. I was too lazy to climb up to my loft to check what I had written on the covers
                      Steve Little
                      Australia.
                      AMCA member 1950
                      • t-jacobs
                        • Jan 2008
                        • 130
                        What do you mean by outside oil written on the 64 cover?
                        • Steve Little
                          • Apr 2008
                          • 915
                          Outside oiler is 1963-64-65. The oil line comes out between the lifter blocks, just near the cam cover/case face.
                          You will see a hole in the pointy bit at the top of that cam cover. This is for the adjusting screw that regulates the amount of oil to the top end.
                          Harley made the chage from oil lines that were drilled up through the side of the barrels to a external oil line.
                          This kept the oil that was delivered to the top end cooler.
                          Note that the cover for a 1965 outside oiler is different again. The cover I have posted is 1963-64 only
                          Regards Steve
                          Steve Little
                          Australia.
                          AMCA member 1950
                          • t-jacobs
                            • Jan 2008
                            • 130
                            Thank you Steve
                            • esquire
                              • Sep 2010
                              • 49
                              I took the pictures and tried to put the right years on them is this right 1954 to1957 and 1958 to 1959 then 1960 to 1962.
                              and then they had the 1963 to 1964 outside oiler with the fins then came the 1965 with no fins but still had the outside oiler.
                              Is this right??
