Ok, so I'm a newbie having a lot of fun with my vintage HD. Have ridden and wrenched on Norton, Triumph and Guzzi for years and understand these machines. The Harley is taking some getting used to.
The shifter rod in the photo is installed on the wrong side of the hand shift lever. But when it's installed on the outside of the lever, the rod hits the bottom of the horn power pack when shifting into 3rd.
Do you suppose the horn power pack should be moved further to the outside, to allow the rod to pass behind it when shifted to 3rd? Or, is the power pack bracket placing the horn power pack itself too low?
http://www.proxibid.com/asp/showImag... Davidson 55FL
Thanks for your ideas.
