what is the difference
  • Glenn
    Member to Remember
    • May 2007
    • 403
    what is the difference between a buddy seat t mount and a solo mount t mount. my 50 had a buddy seat but I want to run a solo seat now do I need a new t mount ?
    Moose
    aka Glenn
  • Magic
    Magic
    • Dec 2002
    • 282
    Glenn it'll be the same with just a rear hardware kit change which you can get easily from several good suppliers.
    • Sargehere
      Member since 1972
      • Jul 2006
      • 971
      No difference. The clamps for the "Buddy Seat Helper Springs" are just removed from the back of the seat T, along with the big, rectangular Helper Spring assy, that is bolted to the rear fender behind the oil tank.
      They were designed to clamp on and hold up the back of your Buddy Seat when you carried a passenger. Don't have them? Don't worry about it.
      Gerry Lyons #607
      http://www.37ul.com/
        • 4790
        Glenn,
        Your buddy seat must also have the nose bracket that is the mount between the seat and tee bar. Without it you can't mount the seat.
        Robbie
