1958 one-year-only parts for FL/FLH??
  • whtaxl
    • Mar 2009
    • 34
    Hi, can anyone tell if there are indeed 1958 one-year-only parts? If so what are they?? I know about the pressed steel Vs. cast iron brake drum on early production that year, but is there anything else that could only be found on a 58?
    Ran
  • droptopford
    • Jan 2010
    • 360
    The black and gold (Palmer calls them black and silver) round plastic tank-badges.
    • bmh
      • Feb 2007
      • 901
      Early swingarms didn't have a zerk.
      Brian Howard AMCA#5866
      • starhub
        • Dec 2005
        • 42
        Saddlebag Bracket
        The saddlebag bracket is welded together and was painted birch white for 1958 only.
        • portagepan
          • Feb 2006
          • 580
          And I think that was just early in the year, until the dealers complained about the shelf space they took up. Are you sure about the birch white? I thought it was different. A whiter white. But I am not sure. I will be glad to know, too.
          Mike
          • dane
            • Jul 2007
            • 62
            cad plated mousetrap cover?
            • upsrod
              • Feb 2010
              • 320
              Slotted rear fender strut screws instead of phillips at least most of the year, Sabre Grey Metallic paint. Also maybe differant machining of the spark plug hole because last year of air cooled plugs, first year 58 to early 62 heads...Rod
              • Steve Little
                • Apr 2008
                • 915
                Duo Glide front fender script didnt have round "R" registered mark at the end.
                The R was added in 1959 and later.
                Steve Little
                Upper Yarra Valley. Victoria.
                Australia.
                AMCA member 1950
                • neilw
                  • May 2007
                  • 72
                  primary case oil drain pipe was 58 and early 59. I have a 59 and wondering if my bikes early or late it's FLH2102.
                  • Perry Ruiter
                    Henderson KJ wanted!
                    • 621
                    The dash base assembly is 58 only. The generator light has a wire running directly from the bulb's socket to the generator rather than using a terminal beside the the bulb as was done in 57. 59 added the neutral light (hand shift never had a neutral light but the base still had a hole for its socket punched into it) ... Perry
                    • Speeding Big Twin
                      • Mar 2010
                      • 433
                      Quote from Neil: 'primary case oil drain pipe was 58 and early 59. I have a 59 and wondering if my bikes early or late it's FLH2102.'
                      Neil, I've posted some info in your thread on the Hydra-Glide forum. Eric
