valve springs
  • Lloyd
    Lloyd
    • Aug 2005
    • 106
    valve springs
    Putting my pan heads together and saw the new springs have a paint line down all coils on inner and outer springs. are they there for a reason and if so why? Lloyd
  • bmh
    • Feb 2007
    • 901
    The reason depends on who made them but such marks are usually used to identify differences that cannot be readily seen by eye. in this case most likely pressure. Yellow stripe could be FLH springs and blue maybe standard or something like that. Factory FLH springs were identified by silver paint.
    Brian Howard AMCA#5866
    • Lloyd
      Lloyd
      • Aug 2005
      • 106
      BMH, These springs are OEM part # 18205-57. They have a orange or red dab of paint on each inner and outer coil............. thanks Lloyd
        • 2024
        Lloyd With a -57 part number are you sure they are FL - might be Sportster XL.
        Jerry
          18205-57 is for a set of both inner and outer springs.
          • bmh
            • Feb 2007
            • 901
            Not sure Lloyd, the part number changed to -57A at some point. the only reference I have is that -57 FLH springs were identified by silver paint. If you are uncertain I would advise checking the pressures.
