Panhead Valve Oiler
  • Lloyd
    Lloyd
    • Aug 2005
    • 106
    Panhead Valve Oiler
    Gentlemen, I've done shovelheads and flatheads but please bear with me as this is my first panhead. I'm very meticulous about keeping parts in order and when I disassembled the heads, oiler parts #18100-49 and #18102-49 were at the exhaust valve. Did some one assemble it wrong in the past? Or is my parts manual wrong as it states intake valve oilers? Thanks for your help & time, Lloyd
  • t-bone
    • Sep 2008
    • 76
    top oiler
    every pan top end i,ve ever rebuilt the oiler was on the intake side.
      There is a Shop Dope that advises to remove them.
      • Lloyd
        Lloyd
        • Aug 2005
        • 106
        If that is the case, let me ask everyone if I should remove the oilers????????? Lloyd
        • Ohio-Rider
          Supporting Member
          • 852
          I've got a good 20k on my engine with out them on there.
          Steve
          AMCA #7300
          • Rooster
            • Mar 2009
            • 543
            The last time I had the valve covers off my '59, one of the oilers was broken; the little 'dripper' portion of it was found loose, had bounced around a bit and was just laying in there.
            • bmh
              • Feb 2007
              • 901
              According to Palmer's book, the use of the oilers is required with certain types of rocker bearings or over oiling will result.
              Brian Howard AMCA#5866
                What Panhead has a rocker arm bearing?
                • flat-happy
                  • May 2009
                  • 543
                  i think they are possibly talking about the little rotator cup that went on the end of the valve stem on 1 or 2 years??
                  • bmh
                    • Feb 2007
                    • 901
                    17611-48, 17614-49 & 17615-49 rocker arm bearings , as listed in the parts book. From my dictionary, bearing  [bair-ing]; In Machinery. the support and guide for a rotating, oscillating, or sliding shaft, pivot, or wheel. Not all bearings are ball or roller bearings.
                      As with a lot of mechanical items the common name is not what is listed in the book. Your reference to rocker blocks as bearings assures us of that. While politically correct the term bearing is confusing to old farts.
                      • bmh
                        • Feb 2007
                        • 901
                        Don't feel bad Chris, the other year when H-D switched to "parent material bearings" for their outboard cam supports. We had to see a motor torn down to figure out they meant they eliminated the bronze bushings and were now running the cams in holes bored in the aluminum plate.
                        • wideglide38
                          • Jul 2008
                          • 656
                          Can anyone tell me what is the Shop Dope # for this bulletin or have a pdf copy they can send or post? I read through my repop Antique Cycle Supply (Vol. III & IV) and H-D Shop Dope book (99410-93) and could find anything about the intake oilers. Thanks
                          William Edwards, AMCA #10035
