unknown seat pan
  • D.Mac
    • Feb 2007
    • 239
    unknown seat pan
    Well, Guys,
    I wasn't sure where to post this, but it looks like a Panhead seat from the top, with speedball trim. Anyone know what this seat actually belongs on? Is it just a weird re-pop?
    Thanks, Doug.
    Doug McLaughlin #6607
    NorCal, USA
  • bmh
    • Feb 2007
    • 901
    Are you refering to the stud locations? Looks like maybe a repro designed to work with little chrome springs instead of a seat-T and pogo stick.
    Brian Howard AMCA#5866
    • D.Mac
      • Feb 2007
      • 239
      Not just the the stud locations, there is also no front mount, just a single threaded insert in the pan. Also the pan is formed and punched in the proper area for the inserts to mount to the seat tee.
      Doug.
      NorCal, USA
        • 4787
        What is the spacing on the studs and the distance to the front hole? In the '50s and '60s it was common to mount H-D solo seats to BMW hardware for use on those bikes. I can check a seat tee for comparison. It could be an aftermarket seat set up for that application.
        Robbie
