whats in my hole
  • Glenn
    Member to Remember
    • May 2007
    • 403
    whats in my hole
    anyone know what the hole was used for behind the front lifter block on a 50 pan. It still looks like it is a half inch deep and maybe 1/4 inch or so.
    Moose
    aka Glenn
    • 2024
    That hole should be blocked. It was where the factory drilled in the cam/tappet oil for 48 and up.
    Jerry
    • Glenn
      Member to Remember
      • May 2007
      • 403
      it does not go thru just the first 3/8 in nothing is in it but it is blocked
      Moose
      aka Glenn
      • motorhead1
        • Dec 2006
        • 171
        It is a cross drill passage to allow oil feed to the heads.
        Ride 'em. Don't hide 'em.
        Dan #6938 FUBO
          • 2024
          Sounds to me like it is exactly like it is supposed to be.
          Jerry
            There should be a pressed-in welch plug at the bottom of it.
            Don't fix it!
