broken bolt and tap
  • Glenn
    Member to Remember
    • May 2007
    • 403
    broken bolt and tap
    in taking apart my 50 pan it appears someone broke a bolt and an tap or easy out in the fender bolt hole on the lower leg. its broken where the easy out is in the aluminum and the bolt is half eaten out by the easy out that is crooked. any ideas on removal
    Moose
    aka Glenn
    Look in the business to business yellow pages for Taps-Extracting. There are four companies in my book. If you can't find that, cut that portion out. Weld it back up. Reshape and redrill.
      • 6036
      A machine shop can cut a hardend steel tap or easy-out with a carbide end mill.
      • Glenn
        Member to Remember
        • May 2007
        • 403
        thanks for the help
        had one broken in the frame and was able to heat it up enough to loose its temper. (I lost mine too) and did drill and get that out
        they were the only 2 bolts on the entire bike that were broken now all the parts for the bike are laying all over the garage. time to sort them out and get some cad plating kits and pakerizing kits and start my project.
        sending the chrome out next week to have it redone.
        anyone have or know were to get an original air cleaner cover mine has the bird on it I don't think that was original or is that ok for judging?
        Moose
        aka Glenn
          That is a Superior air cleaner, an accessory. Accessory's used to be OK. But I have head it said that if an accessory is not an addition but replaces on original part it would not be allowed. Better ask Kevin his latest opinion on accessories.
          • Glenn
            Member to Remember
            • May 2007
            • 403
            got the tap out a machine shop about an hour away had what they call an EDM electronic discharge machine. It desolved the tap and they were able to remove the bolt and it looks brand new
            Moose
            aka Glenn
            • bmh
              • Feb 2007
              • 901
              Cool, even though the machinery sounds vaguely sexual.
              Brian Howard AMCA#5866
              • Paps
                • Jun 2003
                • 1814
                I.ve burned broken taps out with that equipment. It works great. A steady hand is needed though. Got to keep the electode on the tap, not the thread wall. Paps
                • Glenn
                  Member to Remember
                  • May 2007
                  • 403
                  never heard of one of those machines until the helpful people here said to look for tap removal.
                  that was the last bolt on the pan to take it from a running machine to a complete basket case as every nut and bolt has been removed and is ready to glass bead and recoat to the proper cad or park.
                  the happy moose
                  Moose
                  aka Glenn
                  • Carl Olsen
                    • Jan 2002
                    • 261
                    An EDM machine is very common in a mold shop, you submerge the part in a solution called dielectric oil and burn the cavity or in this case the broken tap with an electrode made out of graphite (pencil lead). The electrode is held by the machine head and passes electricity between it and the part to be removed when it almost touches the part, thus burning away the unwanted material. You can control the burn rate by the amount of electricity and the distance between the electrode and the part. This is not a hand held process. It makes a very clean job as you do not disturb the parent metal and can machine the graphite to any configuration that you want. It is hard to believe that pencil lead can remove metal, but it has been done many times for many years.
                    Carl
                    • Ohio-Rider
                      Supporting Member
                      • 852
                      Paps and Carl have described two types of EDM which both work great. There is also the more modern EDM wire machine. It is sort of like a band saw but uses a wire instead of a blade. They are extremely accurate (within .003) and have a higher ft/pm speed than the older extrusion die EDM machines. No good for removing taps though.
                      Steve
                      AMCA #7300
                      • indianut
                        • Feb 2005
                        • 308
                        I have used my Charmilles E.D.M. for 20+ years mostly for making Steel Stamps. Awesome machine!!
                        http://laughingindian.com/
                        A.M.C.A. Member Since 1986
