I'm restoring a 64' duoglide and need help figuring out what type of lower tank mount I'm suppose to have. The piece I'm talking about welds between the down tubes and supports the bottom front portion of the tanks. Some time during this frames life the fatbob mounts were all cut off for a different style tank.
I have seen pans with only one strap of metal spanning the two downtubes and its bent to conform to their shape. I have also seen the new style which has two pieces spanning it creating a flat surface on the front of the downtubes. I can’t find anything in my Palmers so any help on what year they changed and what I'm suppose to have would be much appreciated. The part I found says 36'-84', but I know I've seen pans with the diffent style bracket.
