Guide marker lights?
    Got another input question. On Guide marker lights. How do the numbers run and what do they mean? Thanks, Bob
  • bmh
    • Feb 2007
    • 901
    assuming you are refering to " bullet lights" these are the only marks I know of, I believe the 49 stands for the model year of introduction as that was standard practice on automotive lenses.
    Brian Howard AMCA#5866
      Brain I should have posed my question differently. What I wanted to know was what was before the 49 stamped bullet lights. What were these stamped? This is going to be the first thing I look for at Jefferson next week (It will be good to see Pittsburgh again). I wonder why there never seems to be a visual reference around when your brain housing group thinks up with this shitt.
      • Paquette
        • Mar 2004
        • 438
        The Jefferson meet is NOT near Pittsburgh. It is sort of between Hanover and York, Pa. in York county-----
          It was a joke! And for all of you that didn't know this. There are five Jefferson's in PA.
          • bmh
            • Feb 2007
            • 901
            I believe this is one of the earlier ones.
            • jwl
              • Dec 2001
              • 338
              I think the earlier ones had a 90 degree dogleg bent in the bracket. They were used under the seat and fastened under the seat t with the studs and nuts that bolted the pan to the t. I am not sure if they were stamped with a number or not.
              • portagepan
                • Feb 2006
                • 580
                Weren't the Jeffersons movin' on up, back in the 80's?
                Mike
                • cdndewey
                  • Jan 2005
                  • 438
                  Hello folks....a little late on this...but
                  This is what I have heard. HD started using the stud mounted style as early as 38 and introduced the strap mounted style running or parking lights in 49 with the PH-7 stamping on the back of the strap. The turn signal kit option came out in 50 with straps and studs. About 51 they were stamped with PH-7 and DH-49 on the straps. About 52 they were stamped Guide and DH-49 on the body and are stud mounted to be used as rear signals. By 62 all that was available were the stud mounted ones and were mounted to a separate strap that bolted on to the forks in the front and a bracket in the rear.
                  Dewey
                  • bmh
                    • Feb 2007
                    • 901
                    There is another one you failed to mention. It is stud mounted and the marking appears to read R8-50 or perhaps P8-50. I have a photo of one but the marks are hard to read.
