48 pan threaded intake spigot replacement information needed
    • 8234
    #46
    Originally posted by dukekleman View Post
    "What are you going to do with your knowledge, take it to your grave?"
    Seems so, Duke!
    (I too was a "Technical Trainer", not only for a few years in academia, but throughout my commercial motorcycle career, as I was compelled to train associates to sustain my shop.
    At least that was the business plan.
    Even with two reliable associates for a couple of decades each (off and on), the lockdown of 2020 meant they had to find real jobs.)
    "I use to hold so many technical items closely guarded, like secrets, "
    Of course, Duke, proprietary intellectual property!
    My competition took my ideas and ran with them, saturating my market with inferior options; My own fault, I guess.
    • MarkLindyHugo
      • Dec 2025
      • 27
      #47
      OK, so the story continues, and another question. Looking at the Colony offerings for a replacement OEM nipple they are pointing me to this version with "'O' ring seal". Would you folks agree, or should I continue looking for a more one that is 'original' metal-on-metal. Hopefully if I get this fix right, my son won't need to address the intake again 50-60 years down the road. Thanks again to all that share their knowledge and advice. You are truly a wonderful resource. Mark
      This gallery has 1 photos.
        • 2019
        #48
        Yes I would use the original plumbers type insert and replace the brass seals with PEEK seals from Cotten.
          • 8234
          #49
          Inspect Colony inserts carefully, Mark!
          Not only for length to be certain they will bottom out at the flanges (they usually needed shortening for Knucks), but one older production had disastrously wide chamfers on the flange where seals made poor contact.
          The thin O-rings are a lit fuse, as modern fuels eat them; and the huge rivets are a sin.
          My PEEK seals are for the manifolds themselves, and it is a custom-fit operation, as nearly any used manifold must be reconditioned, and it may be some time before I am back in business, if ever.
          • MarkLindyHugo
            • Dec 2025
            • 27
            #50
            Cotton, thanks for the feedback. As I have not purchased a nipple yet, can you point me to any vendors that you've had better luck with? I'm not set up for machining parts, and the O ring prospect got me concerned. Thanks!
              • 8234
              #51
              I haven't ordered any for a few years, Mark,
              But Colony has usually been pretty good about corrections.
              Frankly, I used the generic Tedd offerings, but they require scrutiny of course.
              (You never know what will arrive from Tedd.)
              • MarkLindyHugo
                • Dec 2025
                • 27
                #52
                Interesting development, I have the old nipple, new V-Twin nipple and the Colony/Sifton install tool at hand. The anvil fits the old nipple with a slight drag. The anvil will not insert into the new nipple. The new nipple id is about 55.2 hundreths of an inch. The old(oem) nipple id is about 56.2 hundreths of an inch. The anvil is about 55.9 hundreds. Anyone have an idea as to if the inside diameter would have changed between 1947-1948, knucklehead to panhead or if this might be a mfg defect? I have an inquiry going with my supplier.
                  • 8234
                  #53
                  I had to look up the tool on fleabay, Mark,
                  If the slots in the anvil are sloped so it would force a rivet outward as it is forced inward, it might work (if you can turn it down enough to slip into the installed nipple).
                  The rivet's a joke.
                  The appliance, puck, and bolt for installing the nipple might work, but I just used an expanding collet.
                  • MarkLindyHugo
                    • Dec 2025
                    • 27
                    #54
                    Since the tool comes without instructions, here is what I surmise. The puck goes in the cap, and once the nipple is screwed into the cap, you tighten the bolt onto the puck locking the threads of the nipple into the cap. Cotton, the item you saw as a rivet is actually a pin - 19 hundreths on the small diameter. I think the intention is that once you have the nipple torqued in place, you drill for the rivet, and temporarily put the pin in to the rivet hole to help prevent the nipple from backing out when you release the bolt, and remove the cap. The anvil has no tapers that I can see, so I am unsure of how it could fully buck the rivet while peening. I may resort to the bolt/nut device i made, as I know i can determine how much force I'm getting on the head of the rivet.
                    More to come, appreciate the help/advice/support.
                      • 8234
                      #55
                      Its still funny to me, Mark!
                      If you cannot remove the 'cap' without the nipple backing out, then what's the puck and bolt all about?
                      I torqued in nipples with a collet, easily removed for the riveting process. (A nut and used seal can be used, if you let the JBWeld set up!)
                      The anvil should force the rivet outward from inside to achieve a seal, and provide the anvil for peening. That's why I preferred cam-shaped anvils that could be turned and held with a wrench, although I also used anvils with 'ramps' that forced the rivet outward, such the top example, and on the right.
                      • MarkLindyHugo
                        • Dec 2025
                        • 27
                        #56
                        Another week goes by, more questions. I ended up swapping out the V-Twin insert for a Colony 1801496, and the dimensions match expectations. Now the rivet seems to be the problem. I measure the inside surface of the insert to the outside face of the head at the existing hole to be 0.431 inches. The oversize 1/4 inch dia rivets supplied with the Colony insert is short as is the other Colony offering 2636-10 3/16 od x 9/16 (measures 0.460 length on the shank). I believe I need 9/16 starting length to get the result I'm after. I am now following Cotton's suggestion and making my own rivets. I will be testing my peening process on some scrap to hopefully avoid cracking the head. I'll anneal them first, so just a whack or 2 with the set tool should do it. Caliper in the photo is set to the depth dimension. From the looks of the dimple ends on the new rivets, are you supposed to swedge them with a center punch, leaving them flush with the head?
                        This gallery has 2 photos.
                          • 8234
                          #57
                          Both of those rivets are silly, Mark,
                          Not only is the head casting more likely to crack after drilling for the huge Colony pin, both of them have flat-bottomed heads, that are incredibly difficult to seat and seal upon the concave surface inside the nipple.
                          Thus it is best to ream the hole 'clean' as small as possible, cut your annealed spike to a self-sealing tapered head with shank at a light press fit, and over-length. Once pressed outward and held firm by the anvil, it can be trimmed precisely to length, and 'upset' with 'just a whack or 2'.
                          (Everyone please note original rivets were not excessively peened to a mushroom, but merely flat-pressed or punched enough to barrel out the shank within the hole, and make the exposed portion of shank only slightly fatter. The MOCO probably did not use just a punch, but some press assembly with enough crunch to serve as the anvil, and deform their flat-bottomed rivets to mate the ID of the nipple as they were upset, and still not split the casting!
                          Note also, how a poor grip between rivet head and nipple ID can allow for slippage upon torque, thus a tapered head can help prevent loosening issues for future generations.)
                          PS: Of course, it is prudent to goober up this assembly, too!
                          • MarkLindyHugo
                            • Dec 2025
                            • 27
                            #58
                            Cotten, on the topic of goobers - have you ever tried loctite 5770? Hi temp / pressure resistant. For steam lines up to 530 degrees. Info i have found leads me to think it may work. Not cheap.
                              • 8234
                              #59
                              I'm not familiar with it, Mark,
                              It might be fine as long as it doesn't taste like saccharin.
                              Until it has been immersion tested in a variety of modern fuels, we must bet on a mechanical seal first.
                              • FNG1
                                • Oct 2014
                                • 201
                                #60
                                Or Hernon 432 good to 450*f
