48 pan threaded intake spigot replacement information needed
  • dukekleman
    • Jul 2022
    • 595
    It's important to remember that the vast majority of the time, we are obviously working with very old aged components. We may be trying to introduce a new component to and old component , like in this case, a new insert to a very old head casting.
    For the reason mentioned above, We have to come up with feasible, affordable and proven solutions for this repair. We can not take an approach of this "brand new" part fits perfect with this "brand new" part. Lets be honest, that is unrealistic and an attempt to make it "brand new" is typically unaffordable for the majority of antique enthusiasts.
    So lets get back to age parts fitment. The first thing that needs to be acknowledged is "Surface Asperities" (Roughness). Every machined part has asperities. The initial asperities change on a particular part over time for many, many reasons. Abuse, corrosion, bead blasting, an attempt to resurface, wrong tooling, lack of mechanical knowledge, etc... all have an affect over time.
    On a intake manifold insert per this post, Your sealing is achieved on the flange surface of the insert to the head casting, not the threads. Why??? Lets take facts about threads. Threads have a Major and Minor Diameter. This is determined and achieved when machining the threads. So Harley Davidson's Major and Minor Diameter in the Cylinder head casting threads may be different than Colony's Major and Minor Diameter on the Insert. This same thing can occur on mismatched hardware...So there is "one" thing to note!
    Second, remember we are talking Old Antique parts again, so years of Mechanical service, Dis-service and Restoration come into play. Years of possible corrosion, Sand blasting, Bead blasting, wire brushing, Cross threading, Galling, etc. all change the asperities, hence the contact area of the threads. NOTE: The majority of all new fastener system threads only contact 10-30% when torqued. This means there is an "Air Gap" in the threaded area of 70-90%! Elastic deformation spreads the load and creates this gaping. The first 2-3 threads carry the majority of the load distribution and it tapers off from there on the other threads.
    So why use a proven sealer? When torqued to a value, the sealer takes up the void ( 70-90% air gap). Taking away the air gap with a proper sealer aids in torque retention and takes away the opportunity for air to wick around the threads and leak. The sealer chosen must resist chemicals seen in its environment of usage, resist temperatures seen in that particular environment and Cure properly. If this is all achieved, the flange surface that does the actual sealing but probably doesn't do its job very well anymore for reasons I've listed above, can be backed up by threads that are sealed on 100% of their area, torqued to a actual value and will not allow air to wick past and lean out our Air Fuel Ratio.
    I hope this helps,
    Duke Kleman
      • 8234
      Simple, Duke!
      If it seals at the 'flanges', it can't get to the threads.
      ... Lets take facts about threads...; This means there is an "Air Gap" in the threaded area of 70-90%!
      Absolutely, Duke,
      That's what I meant by straight threads 'are not self sealing', as there is always a gap at the apex of both internal and external threads.
      It makes us sleep better, Duke.
        • 6018
        Harley-Davidson was fond of plumbago and I'll bet they used that in many plumbing applications. Today, you are required to wear a hazmat suit, and welders gloves to even look at it.
          • 8234
          I thought plumbago was why my back hurt, Eric!
          Indian used some sheet lead oil line seals, and perhaps "white lead" upon their intake nipples, such as this NOS Chief,
          But we need evidence that HD ever used anything.
            • 6018
            That's 'lumbago' and you get that in the lower back from thinking you're still 18 years old and can hork a V-twin motor into a frame without assistance.
              • 8234
              Please, Eric,..
              Which of the twenty-three varieties of Plumbago was HD so fond of?
              Since plumbum is latin for lead, I mentioned Indian's applications, and hoped you knew of a secret sauce!
                • 2019
                I thought plumbago was a mixture of graphite powder and oil?
                Jerry
                  • 8234
                  Jerry
                  That would explain, Jerry,
                  Why we find no evidence HD used a sealer.
                  • PaulCDF
                    • Aug 2019
                    • 1422
                    Perhaps graphite and lead (Pb) ? Particularly as Erix noted considered 'hazardous'
                      • 8234
                      After a few dozen clicks, Folks,
                      Wikipedia finally admitted plumbago was an archaic name for graphite, disused after 1787 or so, when they figured out it wasn't really lead.
                      How it would survive as an intake sealer without a heat&fuel-proof binder is anybody's guess.
                      Other than mechanically-damaged SS nipples, I never encountered leaky Indians,
                      white lead.jfif
                      Harleys leaked more than they didn't.
                      PS: I immersion-tested many sealers, but never linseed oil.
                      • MarkLindyHugo
                        • Dec 2025
                        • 27
                        Thought I'd post an update. I made an anvil out of a nut and bolt, dimpled at the top to hold the rivet head. I used that to push the rivet out as far as possible and keep it from spinning. I used a Dremel cutoff wheel to remove the exposed portion. A couple light taps with a pin punch knocked the pin out without much effort. I applied a good amount of penetrating oil into the rivet hole and around the nipple. I was able to unscrew it almost by hand alone - just a little grip with a pair of pump pliers to get it rolling. Thanks all for your recommendations and advice. Now I have time to get everything cleaned up while I wait for the new nipple, rivet, sealant and install tools to arrive.
                        More later...
                        Mark
                        This gallery has 4 photos.
                        • BigLakeBob
                          • 2767
                          #27
                          Looks great so far, thanks for sharing.
                          Bob Rice #6738
                          • dukekleman
                            • Jul 2022
                            • 595
                            #28
                            Mark,
                            I'm glad you are moving forward and making progress!
                            Thank you for the update and photos,
                            Duke Kleman
                            • PaulCDF
                              • Aug 2019
                              • 1422
                              #29
                              Nice work Mark.
                                • 8234
                                #30
                                You dodged a bullet, Mark!
                                Many nipples tear the threads on their way back out, from distortions around the rivet hole:
                                Sometimes I was able to punch through the casting to deform the nipple inward, and away from the casting, but usually I cut and crushed the whole thing, especially with aluminum heads.
