External Oil Filter Canister - Retaining Hardware
  • Iacovos
    • May 2012
    • 208
    Hello everyone
    I am a bit confused with the external oil filter canister retaining hardware.
    The parts catalogue shows a acorn nut (63852-48) and a washer (63858-49) which is steel i believe.
    Aftermarket rebuild kits give a normal style nut and a copper washer.
    Why was the acorn nut and steel washer dropped by the aftermarket?
    Which combination seals best the canister not to leak?
    Is any form of grease or gasket sealant reccomended?
    Thank you
  • Saddletramp
    New Old Member
    • Aug 2011
    • 129
    I believe there is a small diameter steel washer and possibly two nuts below the filter on the inside bottom of the canister and the 63858-39 (asbestos or maybe it is copper on mine) washer and acorn nut outside retaining the canister. The asbestos or copper washer is the solution for a seal. I have never used a sealant on the bottom of the can.
    James
    • otis71
      • Jul 2015
      • 597
      Originally all seals were made of gasket material. Where the canister mates to the top has a tendency to weep a little over time but I found a dry gasket works best on this application.
      • Iacovos
        • May 2012
        • 208
        Thank you!
          • 4789
          The key to non-leaking canisters is the adjustment of the backing nuts on the rod inside the assembly which prevent collapse of the canister end. When adjusted correctly as the top gasket is compressed the canister contacts the nuts and then the acorn and gasket do a fine job of sealing the pointed end.
          • Iacovos
            • May 2012
            • 208
            Thank you Rubone
            • dukekleman
              • Jul 2022
              • 596
              Lacovos,
              Rubone nailed it. The correct adjustment length of the rod and nut assembly is crucial! I see them incorrect quite often.
              With that said, you must remove the dimple that is most likely in your canister where the seals and outer nut seat. This dimple gets created because the adjustment is incorrect.
              The other reason is people buy various gaskets sets available for the filter housings and their assembly heights vary. This requires the reset of the assembly.
              Try to target for a 0.020" air gap in the end. This will allow proper pressure on your gaskets. It will also allow the memory in the steel of the canister to return when loosened for service.
              Hope this helps,
              Duke Kleman
              • Iacovos
                • May 2012
                • 208
                THANK YOU ALSO dukekleman
                MENTIONING A CORRECT ASSEMBLY ON THE ROD. WE ARE INSTALLING THE OIL FILTER WITH GASKET AND THE FIRST NUT TO SEAT ON THE BASE OF THE FILTER. AND THE SECOND NUT AS A LOCKING NUT.
                THEN THE CANISTER, WASHER (63858-49) AND ACORN NUT. ON THE FILTER CAP THE THREADS OF THE ROD EXTEND AS MUCH FOR THE ACORN NUT TO BE IN PLACE AND SNUG
                ALSO INSTEAD OF THE COPPER WASHER I AM USING 63858-49 ON THE CANISTER AND ACORN NUT (LEAKS LESS BUT STILL LEAKS...)
                AM I MISSING SOMETHING?
                THANKS AGAIN EVERYONE
                • dukekleman
                  • Jul 2022
                  • 596
                  Lacovos,
                  Many times the bottom of the canister is dimpled as I mentioned. This dimple occurs because the rod adjustment was in correct for the stack height of the canister and required gasketing.
                  With that said, if there was a dimple, did you remove it as necessary?
                  Also be sure to verify the top of the canister gasket surface is flat for sealing purposes.
                  Hope this helps,
                  Duke Kleman
                  • Iacovos
                    • May 2012
                    • 208
                    Great thanks a lot Duke.
                    All Clear.
                    We removed the dimple as much as we were allowed. But anyhow we will do another oil change soon and install a new oil filter
                    Will also check the oil filter assembly then.
                    I will be back on this thread in case things go south
                    • Iacovos
                      • May 2012
                      • 208
                      OK SOLVED
                      Believe it or not was the nut underneath the washer. When we received the bike from the museum it had a plain nut.
                      We added the OEM acorn nut that has a flush surface and leaked stopped.
                      WASHER (63858-49) - did a good job.
                      THANKS FOR YOUR INPUT
