Panhead NOS Horn from 6V to 12V
  • mrupp
    • Jan 2022
    • 13
    Hi this is Michael. I am currently finalizing restoration of my 1957 Panhead. I rebuild already alternator and regulator from 6V to 12V. Do you recommend to rebuild also the horn from 6V to 12V? Should I use an resistor or rebuild the coil (double windings, diameter half)? Or just use it like it is? Do you have any experiance or recommendations? Thx Michael
  • BigLakeBob
    • 2767
    My 62 is 12v and I am using a 6v horn power pack, no issues, 7 years now. The small amount of time the horn is activated doesn't seem to affect anything. The grandkids sure put it through a workout, if it can survive their abuse you're good to go IMO.
    Bob Rice #6738
    • Architect
      • Dec 2014
      • 283
      I run a 6V horn on my '46 Flathead, the bike itself is converted to 12V. it works fine, just the tone is high pitched compared to stock.
      • PaulCDF
        • Aug 2019
        • 1422
        Running 6v horn on my 46 Indian converted rest of electrical system to 12v Horn works Great.
          • 5950
          If you are "Restoring" it the electrical system should be 6V. Why go to expense of a new electrical system if the original has been working fine for 70 years?
          • Lyle Manheimer
            • Mar 2008
            • 193
            I would use it as is. Just remember that at twice the voltage it should not be sounded for long periods.
