Turn indicator wiring
  • leversole
    • Jan 2026
    • 46
    The King of the Highway option included factory turn signals....I understand there are no factory wiring diagrams for these...does anyone know if the wires were in their own conduit (two conduits going into the rear fender) or in the conduit for the brake/running light? A picture would be awesome! Logic tells me since they were an add on, they are in tier own conduit,
  • Saddletramp
    New Old Member
    • Aug 2011
    • 126
    They were in the same conduit on my 1960. It all runs inside the rear fender, or mudguard kept t by the fold overs inside.
    • jorrow
      • Feb 2008
      • 347
      Leversole, turn signal wiring diagrams showed up in the 1968-69 year example. Its in your factory service manual.
        • 4784
        • leversole
          • Jan 2026
          • 46
          Mine is 1964...Thanks all
          • leversole
            • Jan 2026
            • 46
            Robbie, is there a Diagram to go with that parts list?
              • 4784
                • 4784
                • FNG1
                  • Oct 2014
                  • 201
                  Amazing. Rubone, Thanks for sharing.
                  • Saddletramp
                    New Old Member
                    • Aug 2011
                    • 126
                    It is amazing Rubone. It will definitely help. Thanks.
                    • leversole
                      • Jan 2026
                      • 46
                      Wow! like ither said, Amazing Thank you!
                      • leversole
                        • Jan 2026
                        • 46
                        I just found the harness section (missed it before?!?) in the "Bible", explains everything as far as wires and conduit!
                        • leversole
                          • Jan 2026
                          • 46
                          Lookey what I found! Don't know if was factory or not but this 3/8s hole is close to the brake/run 3/8s hole...someone stuck the turn wires through the brake/run grommet...I will remedy!
                          Also it is clear that, at least in 1964, the turn signal wires ran in their own conduit from the front terminal block to the fender!
