1964 Duo Glide Oversize pistons
  • leversole
    • Jan 2026
    • 46
    Going to .010 oversize pistons, any recommendations on manufacturers? stay with stock compression? Maybe up to 9 to 1? VTwin? Wiseco?
    • 2020
    I much prefer OEM pistons if you can find them.
    Jerry
    • otis71
      • Jul 2015
      • 597
      I prefer low compression pistons for starting reasons and I don’t need to be a hot rod anymore. I’ve had good luck with Dixie pistons which come with Hastings rings. I prefer their oil ring over oem.
      • vph-d
        • 1088
        Stick to FLH compression, or consider the lower FL compression ratio.
        VPH-D
        • PanheadFred1
          • Dec 2019
          • 75
          I've had good results with Dixie too. BMI Carts on eBay
          • leversole
            • Jan 2026
            • 46
            Thanks all...My hot rods days are behind me! I will look at the Dixie pistons...
            • BigLakeBob
              • 2767
              A word of caution from the pistons at BMI. They are about an hour from me and I've bought quite a few recently. Great people and great pricing. What I found out, even though advertised as a '53-'73 style, the low compression (FL) are '74 newer style with the wrist pin hole being .030 lower which will change compression. The FLH pistons they advertise seem to be correct. Check before use.
              Some of the ones from Tedd's are also advertised wrong.
              Bob Rice #6738
