Hi guys, First of all, thank you for the support you can offer me
I need your help identifying this 1949 Panhead. The engine number indicates a ’49 Year, but it actually has a Springer fork installed
The gearbox is marked K8, and the heads are also stamped 48 – K8, but the engine number is a 49E…..
The engine number 8124 seems too high to be an early series (though I might be wrong), and I haven't found any “P” to understand whether it was originally a sidecar.
The frame has the horn mounts, in the frame and shows XE-35F number 17.
My question is: could this be one of the Panhead produced using leftover parts from the factory?
Or was the Springer fork added later over the years?
Are there other ways to figure out if this ’49 Panhead came from the factory with a Springer front end?
Kind regards
Enry
Kind regards
Enry
