1965 trans. base plate
  • ldfly112
    • Sep 2017
    • 146
    I am putting together a 1965 FLH. I am seeing the part number for the base plate changed after 1964 and a new number for 1965 and newer. What changed in 1965 on the base plate THANKS if you can help
    • 2024
    The 1965 trans plate no long needed the machined bottom slots as the case was now located by the inner primary cover - they are still there but not finished. It also no longer needed the adjuster screw bracket. They are still very easily confused with each other. The easy way to tell the difference is that a -65 plate has a big hole where the adjuster screw bracket used to mount.
    • dukekleman
      • Jul 2022
      • 596
      Idfly,
      The changes were all due to the addition of electric start and a cast aluminum primary with a manual chain adjuster located within on model year 1965.
      Duke
      • ldfly112
        • Sep 2017
        • 146
        I have a couple base plates that are the older version sounds like they will work with no problem on the 65.
          • 4790
          Make sure they are swingarm type not rigid as there is a different hole location on the left front.
