Panhead Frame Ground Bolt and Washer?
  • Iacovos
    • May 2012
    • 208
    Hello
    I am looking for the part numbers (or sizes) of the bolt and washer that secure the battery negative cable to the frame (ground)
    Cannot find it.
    • 4790
    It is a machine screw, not a bolt. If I recall it is a pan head 8-32x1/2 with a matching nut and a star washer between the wire and the frame tab. Look in the knowledge base for a fastener listing.
    • Iacovos
      • May 2012
      • 208
      Thanks Rubone!
      • otis71
        • Jul 2015
        • 597
        My 2 Panheads have a 1/4-24 round head screw with a lock washer that fastens to the tab on the right side of the frame.
        • Saddletramp
          New Old Member
          • Aug 2011
          • 130
          None of my publications mention the ground to frame hardware either. For what it's worth, both my '48 and '60 panheads factory frame ground tabs appear to accept no larger than a No.10 screw or bolt. The '48 has a No.10-32 pan head type screw 3/8" long with a square nut and no washer. Probably should have a hex nut and star washer as Robbie stated.
          My replica harness soon to be installed on the '60 has a terminal end on the ground to frame wire that is larger than No.8 and no larger than No.10. My parts book calls for No.10-24 battery terminal screws, so I will be using that size on both ends of the ground wire. and probably with an external star washer and hex nut. Unless of course more info is found.
          James
            • 6039
            I looked at my '48 & '51 FLs and the ground screws on the frames are 10-32. I could very well have drilled them out to accommodate #10 screws but I would be surprised if they were originally made for a 1/4" fastener. At the battery terminals, special 10-24 fasteners are used so I would think H-D would stay with the #10 size as James said above. I love these weird minutia inquiries
              • 4790
              My bad, they should be 10-32.
              • Iacovos
                • May 2012
                • 208
                Thank you everyone and no worries Rubone
