Frame identification
  • Jdiesel25
    • Mar 2018
    • 295
    Not sure if this is a panhead frame. Looking to find year and model please
    left side neck XE-35 F not 100% on the F
    right side neck casting stamp 15
    front engine mount 48E-621
    left side car loop 48E 762 01
    left axle plate XE7 casting stamp 9
    right axle plate XE6 casting stamp 7
  • Jdiesel25
    • Mar 2018
    • 295
    First set of pics
    • Jdiesel25
      • Mar 2018
      • 295
      Second set of pics
      • marksg
        • Mar 2023
        • 128
        I figure it is a 49 and up since I see a damper pin at the neck. Also don't see the horn mounting on the down tubes. Makes it a Hydra Glide frame. However the numbers on the frame make it a late 48' which would be a springer.
        Edit: Not sure what I was thinking. 48' had no horn or mounting blocks on the down tubes but 49' did so a late 48' it is.
        • marksg
          • Mar 2023
          • 128
          Looking some more at the down tubes and no horn mount. I think it has either had the horn mount ground off or it is a very early 49'
            • 4790
            Most likely '48 with full round downtubes and no horn blocks. The boss for the pin was on them and late '48 was drilled as well, just no pin. Someone likely put a Hydra-Glide fork on at some point and installed a pin.The reinforced top motor mount ans the 7 and 9 axle plate numbers all point to late '48.
            • dukekleman
              • Jul 2022
              • 596
              Exactly my thoughts also Rubone!
              • Jdiesel25
                • Mar 2018
                • 295
                Thanks everyone!
                  • 6039
                  I also agree (as usual) with Robbie. My '48FL has the neck damper pin boss and the hole was filled with Bondo because it had been a chopper; otherwise, an un-tampered neck from a bon-e-fide (but molested '48. This is the kind of stuff that makes early production Knuckleheads, and Panheads so interesting.
                  • droptopford
                    • Jan 2010
                    • 361
                    Yes!! To us anyway.
                    This time it was my wife looking over my shoulder Eric, She says we're all a bunch of geeks.
                      • 6039
                      I guess your wife is correct, Clark. I remember when motorcycles used to be "cool" and now it seems they are a Poindexter's paradise. Having said that, I am happy about it, and love wallowing in the endless details, minutia, and doing Spock's "Vulcan Mind Meld" with other goofy f**kers that love this stuff. I spent the day in my shop screwing around with the Henderson and really enjoying it.
                      I deleted a my last paragraph because it is happy hour, and let's just say we all love old motorcycles
                        .... let's just say we all love old motorcycles
                        Is it OK, Eric,...
                        If, after so many decades trying make a living, I'm only ambivalent?
                        (Don't worry, I can easily reserve hate for paint.)
                        • Jdiesel25
                          • Mar 2018
                          • 295
                          My friend is going to be selling this frame if anyone has any interest make an offer. Thanks
                          • dukekleman
                            • Jul 2022
                            • 596
                            What state is it located in?
                            • Jdiesel25
                              • Mar 2018
                              • 295
                              Pennsylvania
