Piston Buying
  • BigLakeBob
    • 2768
    Piston Buying
    Where can I buy correct pistons for 705/706 rods for 74"? All I keep coming up with are '74 newer which has a .03 different wrist pin location. Tedd advertises '41-'77 but they are not, they are '74 and newer. I've been to BMI Carts which has old Dixie and all of theirs are '74 and newer? I have not tried Eastern yet, but probably from the same Taiwan plant as Tedd's. I have NOS OEM to check against and deffinitely show the .03 difference introduced in '74. Thanks.
    Bob Rice #6738
    • 8247
    I've a couple of suitcases of Superiors, Bob,..
    Can you be more specific?
    Got your old DIXIE catalog handy?
    (Mine's nearly destroyed..)
    • BigLakeBob
      • 2768
      Tom, I do not have an old Dixie catalog. As far as being specific. This is what I bought from BMI that are all '74 newer. Their part # (maybe same as Dixie) J11228L020 74" Low Comp +.020, J11228L040 Low Comp +.040. Then I tried M11228L040 74" Low Comp +.040, M11228LSTD 74" Low Comp STD. All '74 newer wrist pin location. I just tried Tedd 11-0313 74" +.060. Same "74 newer. Tedd advertised '41-'77, should be '74 I believe. Curious if anyone checks the location or just assumes you are buying as advertised?? I have quite a few cylinders and just wanted to buy pistons for future use that are of the -53(low comp) or -55 (high comp) HD style not the -74 style. Thanks for the response Tom, appreciate the help.
      Bob Rice #6738
      • dukekleman
        • Jul 2022
        • 598
        Bob,
        What is the compression height dimensions you are measuring on your pistons?
        I can measure some I have on hand as an comparison...
        Duke Kleman
        • dukekleman
          • Jul 2022
          • 598
          Bob,
          Perhaps these measurements will help answer questions regarding the decision to purchase of the V twin piston kit.
          Hope this helps,
          Duke Kleman
          • BigLakeBob
            • 2768
            Even though the bottom of the skirt is a non functioning surface it is very consistent in measuring the wrist pin height regardless of high or low compression.
            pre '74 to centerline of wrist pin is 1.406" (1 13/32)
            '74 newer to centerline of wrist pin is 1.375" (1 3/8)
            Checking from bottom of oil ring land to centerline of wrist pin
            pre '74 .656" (21/32)
            '74 newer .687" (11/16)
            Bob Rice #6738
            • BigLakeBob
              • 2768
              Duke, thanks for the chart. The ones I just bought from Tedd are low comp so I can't compare with your chart. The +.06 I just got from Tedd 11-0313 low comp measure approx. 1.937' (1 15/16) from top of piston to c/l of wrist pin.
              Bob Rice #6738
