Hello everyone
We had been working on a second 64FLH (not the one we rebuild the carb and changed manifold seals - which is working great).
on this second FLH we did timing, new plugs and reset the carb as per manual.
The bike would run ok however if you tried to open the throttle quickly it would hesitate/cut-out.
After three runs the spark plugs fouled (see pics)
How can i back track and fix this?
Where to start?
Facts are:
1) Carb was rebuilt 2-3 years ago
2) In a box given with the bike i have found a spare brass float (so probably carb was rebuilt with brass float)
3) Have not performed vacuum leak and not sure if manifold seals where replaced at the time the carb was rebuilt
4) on couple of occasions i found some gas leak from carb (believe from small hole)
5) Both plugs appear to “blacked out” the same (see pics)
The idea is to pull off the carb and do a rebuilt and change the float if brass
also change the manifold and carb intake seals
Anything else i could be missing?
Thanks a lot
Where to start?
Facts are:
Thanks a lot
