1964 FLH Spark Plugs Fouling
  • dukekleman
    • Jul 2022
    • 598
    #46
    Lacovos,
    1) What is the setting on your high speed needle?
    2) What size is your main jet?
    3) Have you verified spark advance degrees?
    4) Is your float arm and float set correctly and sealing properly?
    Duke Kleman
    • Iacovos
      • May 2012
      • 208
      #47
      Originally posted by dukekleman View Post
      Lacovos,
      Duke Kleman
      Hello Duke
      Thanks!
      OK I believe have narrowed down the culprit
      The high speed needle was 3.5 turns out.
      Low speed 1.5-2
      Have put the high speed at 3/4 out as per Cotten's suggestion.
      Rode the bike and Sparks Plugs cleared!!
      So looks good so far
      Have not had the chance to ride it any further
      • dukekleman
        • Jul 2022
        • 598
        #48
        Lacovos,
        I'm glad your were able to work through things and get some positive results.
        Safe riding,
        Duke Kleman
        • Iacovos
          • May 2012
          • 208
          #49
          Thanks a lot Duke
            • 8247
            #50
            Let us remember, Folks,
            There is no "correct" number of turns on needles, because adjustability makes any spec moot.
            And six decades of duty or abuse (plus aftermarket insults) can result in a great variance,
            Particularly after dressed clean:
            And beware of obvious re-dressed needles sold as new...
            So the proper setting is that where it performs best, after both circuits have been trialed alternately, ... and as needed, especially when changing fuels, altitude, seasons, etc.
            • Iacovos
              • May 2012
              • 208
              #51
              VERY WELL SAID SIR
              Thank you for getting into these details with close up pictures
              They do help a lot
              Jack
                • 8247
                #52
                The second pic in my last post, Folks,..
                Shows wear upon the needle from the spring collar, with probable wear upon the collar bore as well. Air is metered through this gap similar to a jet, so replacement is prudent when the needle is scarred or the bore is egged.
                Note that the fresh collar should be able to shift smoothly as the lift lever is actuated, or there will be wear. Inspect the deck it rides upon for wear (before and after):
                Dressing the point as shown before-and-after in the third pic can be easily achieved by spinning in a drill press or lathe, and applying a stone:
                A HS needle is shown; A red India stone is best for brass idle needles.
                I arbitrarily dressed all points as a matter of inspection.
