Panhead Wiring - Additional Guides / Material
  • Iacovos
    • May 2012
    • 208
    Hello Rubone and thank you for your reply.
    My concern is not how to connect the wires, but the actual routing of the wires from the timer to the coil..
    Does the loom just run down the timer through a clip at the crankcase, then after the rear cylinder turn towards the coils?
    Thank you
      • 4791
      Thank you
      Same as every other model, there are just two wires instead of one.
      • Iacovos
        • May 2012
        • 208
        Noted! Thank you!
        Its just that when you spend time getting it down to the details, every detail is haunting you back!
        • BigLakeBob
          • 2768
          Originally posted by Rubone View Post
          No, the horn should not honk in the off position.
          Are you sure for a '61-'64 model? Maybe I'm incorrect, but my '62 is wired per the schematic on page 5B-20. The wire goes directly to keyswitch terminal #1 which is always hot. On my '69 the wire goes from the button to terminal 25 then to keyswitch #5 which needs the switch turned for that horn to work. Never thought much of it until my grandson was on the bikes and one horn would work and the other wouldn't. Am I wired correctly?
          Bob Rice #6738
          • Iacovos
            • May 2012
            • 208
            Hello again
            Can someone explain why the regulator can either be found on the coil side or on the right side on 64 duo glides?
            Was this dictated by the equipment? Or if it was a police bike?
            Thanks a lot
              • 4791
              Right side is standard civilian bike , two component regulator for standard Model 61 generator. Left side is three component regulator for radio equipped bikes used along with the fan cooled generator. The oil tanks differ for the specific use as well due to the large battery needed for the radio bikes.
              • Iacovos
                • May 2012
                • 208
                Thanks Rubone!
                What i can see here is a regulator on coils side with three components as you say.
                The 64 Panheads we have here are all Police and therefore all regulators are mounted on the coil side so have no other point of reference.
                Hence the question
                • Iacovos
                  • May 2012
                  • 208
                  Therefore is it correct to say that bikes with the regulator mounted on the LH side have definitely a fan cooled generator?
                  Irrespective if the bike has a traditional horseshoe oil tank?
                  Need to know if i have a fan generator as it will matter on the wiring i am doing.
                    • 4791
                    The appearance of the generator is very obvious if fan cooled. It has a large cast aluminum end on the clutch pedal side.
                    • Iacovos
                      • May 2012
                      • 208
                      Thanks again Rubone
                      • Iacovos
                        • May 2012
                        • 208
                        Good day everyone
                        My terminal post behind the coils needs to be rebuilt.
                        I have not managed to locate the parts online by searching for the individual items of the terminal posts as per the parts manual.
                        Example the insulator 71098-38, washers, the insulating board 72345-48 etc (see picture)
                        Even from aftermarket i can find a few kits by Colony
                        But even those come complete with the terminal box and also these “star” washers which do not appear in the manual (see picture)
                        Have the modern components changed and not all parts needed to rebuilt these terminal posts?
                        i just need the internal components and dont want to throw my box away as its the OEM one, for an aftermarket one
                        How do you all go about to restore these terminal posts?
                        thanks
                        • Iacovos
                          • May 2012
                          • 208
                          #27
                          Hello fellow members
                          Have a question please:
                          Voltage Regulator (3 unit) BATT Wire Red
                          In Palmers it says that the routing of this wire enters the seat terminal box from the upper front side. But on the upper front side the wiring loom with four wires coming from the switch enters the terminal box.
                          There is very little or no room to accommodate both wire looms on the upper front side of the box.
                          Is this a typo and should the regulator wire enter the box from the upper rear side?
                          Any advice please as it is puzzling me.
                          1964 FLH Duo Glide
                          Thanks a lot everyone
