Linkert Manifold Gaskets
  • otis71
    • Jul 2015
    • 598
    Any suggestions on the best manifold gaskets to use? I have some smooth ones I believe came from Colony kits and also have some course ones that look like asbestos I bought in bulk at Oley. Or none of the above?
    • 8248
    Asbestos sounds yummy, Otis!
    Otherwise, most modern productions have an embedded sealant.
    Beware of three-bolt gaskets cut disastrously close to the top bolt hole.
      • 6044
      What a useful observation and advice, Tom. I'm putting carburetor on tomorrow, so I'll be looking at that gasket. Thanks.
        • 8248
        If your manifold flanges are ground/lathe-cut, Eric,..
        Greased butcher paper will do.
        Takes a good gasket hammer though.
