1965 FL frame
  • Pete Engelman
    • Apr 2018
    • 147
    1965 FL frame
    I was looking on the internet this morning and a guy is selling a frame for a 1965 FL. He states that the 1965 FL models had a 1 year only frame. Does anyone know if this a true statement and if it is what is the difference between 65 and 66 frames? The 65 FL I am restoring has a C5 stamped on the frame on the top engine mount at the frame.
    Pete:::::::::::::;;;;;;;;;
  • sswaney
    • 303
    Pete
    I have a 66 and back when I was looking for a frame for it I don't recall there being any differences.
    Your date code puts your frame at March of 1965 production which may work for you.
    I'm curious how that compares to your Motor number. I tried to determine when in the production sequence things switched over.
    For instance could an early production 66 have a H-5 or I-5 dated frame stamp?
    Also does your frame have the left rear frame reinforcement bracket added?
    I know a lot pre 68 frames had this feature added at some point but I've seen quite a few without it.
    Look forward to others take on this question.
    • Pete Engelman
      • Apr 2018
      • 147
      Thanks Sswaney
      I was told the gusset was a factory recall then upgrade for the 1966 MY as the shovel made more HP and torque than a panhead. I have a 66 FLH as well but have never looked at that number on the engine mount. It is quite original so next time I have the tanks off I'll be taking a look. My friend said that you can put a pan in a shovel frame but a shovel won't fit in a pan frame, the center post had to be dented in for a shovel to fit so, I almost wonder if HD made the center tube slightly longer in 1966 making the 65 a 1 year frame for the pan with electric start primary??
      Pete::::::;;;;;;;;;;;
      • otis71
        • Jul 2015
        • 598
        Items manufactured in the latter part of the year would be used the following year including frames. I had 2 69 Sportsters with 68 stamps. One was H 8 and the other I 8. Both had very low engine numbers.
          • 2026
          Originally posted by Pete Engelman View Post
          Thanks Sswaney
          Pete I've never had a problem putting a Shovel engine in a Pan frame although sometimes the head does come real close to the seatpost but I think this is more related to perhaps the frame sagging a little in the middle.
          Jerry
          • dukekleman
            • Jul 2022
            • 599
            Pete,
            I've also never had a issue putting Shovelhead's in a Panhead frame as Jerry mentioned.
            However when you install a Panhead into a shovelhead frame, the rear cylinder head casting and D-ring hit on the seat center post. I've seen this many times...
            To the best of my knowledge the center post would be different on a 65' verse a 66'
            Hope this helps,
            Duke Kleman
            • Pete Engelman
              • Apr 2018
              • 147
              My frame has a C5 stamp and the engine number is 4 digits starting with 9 so likely mid year
              Pete:::;;;;;;;;
              • sswaney
                • 303
                Thanks for the frame stamp/engine number reference Pete.
                For what it's worth, the frame gusset plate shows up in the 61-71 Parts book.with a 47261-68 part number.
                • Pete Engelman
                  • Apr 2018
                  • 147
                  Thanks every body for your insight
                  Pete::::;;;;;;;;
                    • 8248
                    So,...
                    What's a '65 frame worth, Folks?
                    (askin' fer a friend...)
                    • sswaney
                      • 303
                      I have bought a sold a few 65 to 69 types in the $500-$1500 range.
                      I gave $1200 for my 66 frame ten years ago.I suppose some would think the 65 version would have more value as those bikes bring more money.
                        • 8248
                        Bet now you wished you kept them, SS!
                        • sswaney
                          • 303
                          That's a good one Tom. I wish I had everything I ever sold!
                          Always buying or selling something to get somewhere.
                            • 8248
                            Still buyin', SS?
                            How many '65s you want?
                            • John Guntner
                              • Feb 2007
                              • 192
                              Back in the 60's I had a 1956, 74" panhead. If memory serves me correctly, the frame was a straight leg, not a wishbone type.
