need oil tank
  • ldfly112
    • Sep 2017
    • 146
    need oil tank
    i am starting a new panhead . 1957 straight leg frame the motor is a 1959 fl i want to utilize a 65 - 69 alum. primary with electric starter. anyone have any suggestions of which oil tank will work trying to keep it looking as stock as possible thanks if you can help
  • dukekleman
    • Jul 2022
    • 595
    Paugcho makes a horseshoe style tank that clears an aluminum primary drive system. Most likely a little bit of fabrication will be required to get things mounted but it'll have room for a proper AH battery.
    For these reasons I would order it unfinished...
    Duke
      • 8234
      Duke
      I've got a veteran in black, Idfly!
      No ugly side-bung either....
      Ran it in a '65 for decades; Some mount adaptation necessary, (I lost the bolt-on front bracket removed for ease of installation) but reasonable if you pick it up at Davenport.
      (If I got to box it: Not so reasonable...)
      PS: Just checked fleabay, and those York tanks look pretty charming!
      • RichO
        • Dec 2001
        • 903
        I've got the same oil bag in my 1940 rigid with electric start with tin primaries and a ratch top. Can use an FX battery. Just sayin'. I think Teddy calls them the York unit.
        DrSprocket
          • 8234
          But the Paughco's have the 'seamless' look, Rich!
          Even though it has enormous sentimental value,... .. . .
          I'll have it at D-port.
          PS: "Bag" must be a californication thing, right? Sleazyrider dispersed?
