64 panhead turn signal wiring
  • maxglass
    • Mar 2008
    • 118
    Greetings
    I am trying to put turn signals on my 64 panhead. The fronts are not a problem, the rear's have become a challenge. Judging from the holes where the signal bar mounts, this bike didn't come with turn signals from the factory. The holes look like they were hand drilled and there's no holes for the wires. I would guess that the wires run in the same metal loom as the taillight wires and come out in the same place, but that's only a guess. where should the wires go through the fender at? Any idea on where the wiring might tie in at?
    Thnaks
    Max
  • dukekleman
    • Jul 2022
    • 599
    Here's a picture of original sheet metal with the original HD lights installed. Nothing aftermarket...
    see the notes I've attached with the photo on the bottom of the image.
    Hope this helps you,
    Duke
    This gallery has 1 photos.
      • 2044
      Dukekelman is showing the '58-'62 style.'63- was the aluminum bracket under the tail light.
      Here is a '63 & OP '66
      • maxglass
        • Mar 2008
        • 118
        Guys, helps a lot. Great looking bikes.
        Thanks again
        Max
