1948 Panhead FL – gearbox mounting bolt question
  • harleygreg
    • Oct 2018
    • 215
    Hi – see images enclosed.
    The two bolts that hold the gearbox plate to the frame maybe the incorrect thread/length and maybe upside down???
    From the parts list diagram, these would appear to be part number 4320 – 3/8” x 24 x 1 1/8”, but the bolt has to go through the plate and the frame meaning it has to be considerably longer than 1 1/8”??
    Can anyone give me the correct part number, and/or the correct length/diameter/thread of the bolts/nuts/washers, and indicate which way up they should be?
    Greg
  • dukekleman
    • Jul 2022
    • 595
    Those are supposed to thread into the frame.
    It appears someone has installed a stud and nutted the top side?
    • dukekleman
      • Jul 2022
      • 595
      The fastener number should be #4340
      Description: 3/8 - 24 x 1 1/8"
      Also required would be a lock washer with the fastener
      Hope this helps,
      Duke
        • 6010
        Colony is a very good source for H-D fasteners, and their catalog is very educational. A common rule of thumb for Harley-Davidson fasteners is; 'one thread showing above the lock washer, and nut in an assembly. I don't know what H-D engineers dictated, but Harley-Davidson was a very good engineering based company, and you can count on their parts, and quality. Also, H-D parts books give dimensions for bolt size, t.p.i., and length based on part #.
        • harleygreg
          • Oct 2018
          • 215
          Thanks everyone
            • 6010
            This parts book shows all of the assemblies in exploded views with reference to part numbers, and an index of fastener dimensions. As Gene Harper used to say, you can learn everything you need to know by studying a parts book. This ebay book shows before and after 1948 which is most valuable.
            https://www.ebay.com/itm/13466097811...Bk9SR9Ku3PmvYg
              • 4779
              You can never have too many parts books and supplements for this old iron.
                • 6010
                "You can never have too many parts books and supplements for this old iron."
                The absolute truth.
