Well , the supposed moveable lock plunger is not coming out...any ideas on removal..I tried to DRILL a small starter hole in end thru welch plug. hole ..could not even scratch it..gonna need a better bit I guess...thought about trying to cut the small connecting part of plunger shaft in two pieces thru the key lock hole cavity...any ideas on something to cut it?..something that is small enough and tough enough??...I need some brain stormin ideas..thanks 49er
more on the fork lock
fork lock +#$#@
....I don't think there is any way to weld or tack a rod to it thru welch hole..and I doubt if it would pull out anyway..it (plunger) is really jammed in there. I was able to cut the plunger in half thru lock cavity...but I CAN'T EVEN GET PLUNGER HALF TO MOVE BACK BY HITTING IT thru welch hole with a drift or forward thru cavity....its stuck and so am I!!..49ER
I have drilled them out in the past and this works excellent. After all it is ruined already, just make sure to stay on center and start with a pilot dril and work your way up. When you get to almost the size of the O.D. you will be able to peel the rest out and clean the hole for the new plunger. Good luck.
Carl
