Original Swingarm Panhead Rear Fender Strut Identification
  • Bohemian
    • Jan 2023
    • 7
    My parts book shows 58 to * FL, FLH for
    59933-58 Right, 59932-58 Left.
    I've seen some being sold as 58-62 and many other 58-76 & other variations up into the 1980's.
    Looking at pictures online I see some with 5 holes, some with more. The Palmers book I have shows 5 holes on the 62 Prototype bike with no luggage rack or bags.
    Looking on the fender side I see at least the following variations...
    1. "Zel" Variation
    2. With a spot welded support at the front (at least two spot welded variations).
    3. With a tack welded support at the front.
    4. No extra support at front of support.
    I have not seen any with any manufacturers markings or part numbers other than the Zel (Zodiac Enterprises Limited).
    I understand the FL & FLH Panhead Fender Struts had counter sunk holes.
    So is there a way to visually identify a original swingarm harley panhead fender strut from a repop?
    does anybody have any pictures of known originals, inside & outside?
    I can't seem to find the answer in any books I have or the internet so far.
    I have a 62 FL so if there's a 5 hole 58-62 version that'd be good to know as well.
    thanks in advance.
    AMCA #44768
  • vph-d
    • 1088
    The struts were the same from 58-76, and 77-84.
    vph-d
    • otis71
      • Jul 2015
      • 597
      I don’t know if this is relevant on big twins; aftermarket sportster struts have slightly more material after the last bolt hole but not enough to notice without one of each in front of you.
      • rbenash
        • Jul 2001
        • 643
        Originals on my 65 are 5 hole.
        I think all Duo Glides up through early shovel years were all 5 hole as well.
        Owners tended to ad more holes as they modded to their own desires :-)
        The original holes have counter sinking to accept original oval head screws except for the ones behind the shocks which were larger in diameter and not counter sunk.
        Ray
        AMCA #7140
        • rbenash
          • Jul 2001
          • 643
          This gallery has 2 photos.
          Ray
          AMCA #7140
          • Bohemian
            • Jan 2023
            • 7
            adding some images for further clarification of the differences i am seeing; inparticular the inside/fender side is where i am seeing the biggest differences; so i am not clear on how to id a original h-d panhead swingarm fender strut yet...
            This gallery has 5 photos.
            • Bohemian
              • Jan 2023
              • 7
              more variations...
              • Bohemian
                • Jan 2023
                • 7
                5th variation inside...
                This gallery has 1 photos.
                • Bohemian
                  • Jan 2023
                  • 7
                  still looking for some pictures of the inside of known original panhead swingarm fender struts, off a bike showing welded or spot welded style on that inside reinforcement plate; can't find anything in my palmers books about it. still no luck on the interwebs; so many different ones out there, there's gotta be a reliable way to tell repop from og; seems to me that welded or spot welded reinforcement you can only see from the inside would be a compeling id in combination with the well known diffs thanks in advance.
