48 Panhead - a few more questions post judging
  • harleygreg
    • Oct 2018
    • 215
    ignition switch top.jpgHi – I’m limited by the five photos, so here a few more easy questions
    5 - see nuts photo - which way should the nuts be put on?
    6 - se Jiffy stand photo - which side of the frame should the nuts be on? inside or outside? judges say outside, parts book shows inside
    7- see ignition switch photos - cover should not have a lip at the end? It should appear as in the 'white' photo, not as on the bike? Correct?
    Thanks, Greg
  • vph-d
    • 1088
    Hi Greg,
    I can't see any of these photos...
    5 ??
    6 the jiffy stand brkt is mounted with 4 bolts, the nuts are on the inside
    7 the ign switch cover should not have a "flip"
    vph-d
    Oh, I'm the guy who pointed out your 48 had rechromed rims...
    • harleygreg
      • Oct 2018
      • 215
      thanks, hope you can see the photos now?
      • vph-d
        • 1088
        Hi Greg,
        The ignition switch in the picture is aftermarket, as is the separate cover, neither look like the original part.
        The flat washer face side of factory nuts go against whatever you are bolting together.
        vph-d
        • Speeding Big Twin
          • Mar 2010
          • 441
          I haven’t got a close-up of the required area on a 48 Pan but I have factory photos of some Big Twins from other years. First is a 1941 prototype Flathead.
          Next is a 1947 prototype Knucklehead with 1946 engine.
          Third is a 1954 prototype Panhead with 1952 engine.
          Fourth is a 1955 prototype Panhead.
          Eric
            • 2044
            I recently looked at a low mileage OP early '47 Knuck....one of the first 400 1947's built.
            The bottom 2 bolts for the kickstand were early style,plain faced coarse thread with large hex,nuts on backside.
            The top 2 bolts were CP fine thread,as shown in 1948 parts book...nuts on backside.
              Notice all visible bolt heads are CP on this 1948.
              • ammorest
                • Sep 2008
                • 305
                Originally posted by vph-d View Post
                Hi Greg,
                vph-d
                Strange Bird was at the Florida meet and I noticed he has the switch covers availabe in chrome or brass you can have chromed yourself. They have the correct downturned tip.
                Dave
                • harleygreg
                  • Oct 2018
                  • 215
                  thanks guys
