A new problem
  • Freeman
    • Aug 2021
    • 165
    A new problem
    5FCBECE4-D518-4C7B-90A4-65AD67286950.jpegDC6DE594-D194-4F4E-852B-5ED9E74E47FD.jpeg04A05F28-6F89-41BB-ADE9-68C36782F7EC.jpeg
  • Freeman
    • Aug 2021
    • 165
    I don't know how to replace it. This installation surprised me.
      • 2024
      Freeman
      The first picture looks like an after-the-fact fix. Originally there was no seal in the engine, just an oil slinger. Someone put in an oring and then glued a seal. Kits have been available in the aftermarket for years. The right most nick circled I would not worry about but the other nick in the original slinger might be an issue. Behind the oring should be a snapring holding it in. That needs to come out and then in theory the slinger can come out. Admittedly this is easier done with the engine dismantled.
      Jerry
      • Freeman
        • Aug 2021
        • 165
        Originally posted by Jerry Wieland View Post
        Freeman
        Jerry
        Thanks very much! Do you have any specific information about the kit? I would like to replace it
        • Freeman
          • Aug 2021
          • 165
          This gallery has 2 photos.
          • Freeman
            • Aug 2021
            • 165
            What kit do I need to buy to replace it? I don't have the information and I don't know what to buy.
              My guess, Freeman,..
              Somebody tried to use a roller bearing for the sprocket spacer, and then thought the O-ring and 'goober' would seal against oil, probably for a belt-drive.
              If a belt-drive is installed, the shouldered thrust washer pressed into the main bearing housing must be replaced with a modern hybrid with a seal.
              If you have a chain-drive, you only need the proper sprocket spacer.
              • Freeman
                • Aug 2021
                • 165
                The guess is absolutely correct. Modern I don't know what to buy, can you recommend it to me。Thanks a lot.
                  We need more information, Freeman!
                  I must ask again: Is there a chain primary drive provided, or is it an after-market belt-drive assembly?
                  The original chain drive is easiest, by far.
                  • Freeman
                    • Aug 2021
                    • 165
                    • Freeman
                      • Aug 2021
                      • 165
                        I know little about belt-drives, Freeman,..
                        So others will give better guidance than I, but please search Colony Sprocket Shaft Seal with Snap Ring #7411-2 Fits 36-54 HD Big Twin
                          • 2024
                          Freeman
                          The kit would probably come from Tedd's V twin but I think you need a dealership to order from them. J&P and numerous other vendors sell their stuff on the internet. Just look for pre 1955 HD sprocket shaft seal kit.
                          Jerry
