fuel tank repair fittings
  • 65flh
    • Feb 2018
    • 35
    Does anyone have a source for the right side fuel fitting, tank is going to the weld shop to get a hole repaired, bike is 65 flh with 5 gallon tanks
  • 65flh
    • Feb 2018
    • 35
    This gallery has 1 photos.
      • 8248
      Sorry nobody speaks up, 65flh..
      Its a common flare, so find a similar steel fitting, and carve it to sit within the rolled ring on the tank, after shaving off the damaged nipple.
      Then tell your welder that if he can't silver-solder, he's a one-trick-pony.
      • 65flh
        • Feb 2018
        • 35
        Thanks for the reply Tom, I found someone that had a repair fitting and was nice enough to sell me one. I also found that the flare fitting is an an-4.
          • 8248
          Many hardware stores will sell you something you can cut and use, 65flh....
          The trick is cutting and applying it without it looking obvious.
          (Or leaking, of course.)
          PS: Hope it was steel!
