Seat Spring Retention
  • jim wagnon
    • Dec 2021
    • 137
    Hello all, which buddy seat overload spring frame brackets are used on a ‘65 FLH? The hook latch style at the bottom or the style at the top where the peg on the bottom of the springs just slip in?
    Jim
    This gallery has 3 photos.
    • 8248
    I thought the hook-latch type was '65-only, Jim!
    But I am wrong so often..
    • jorrow
      • Feb 2008
      • 347
      They use the hook latch in '65, discontinued probably because the hook handles break off at the weak point, so use sparingly.
      • jim wagnon
        • Dec 2021
        • 137
        One is already broken as you described. Thanks Jorrow and Tom For the reply.
        Jim
          • 8248
          Jim
          Don't throw it away, Jim!
          If the pieces are there, I would suggest a silver-solder repair, such as upon saw blades and such.
          They ain't gonna be re-popped soon.
          (You will be forced to fake the cad, however, as it doesn't stick the same...)
          • jim wagnon
            • Dec 2021
            • 137
            Definitely won’t throw it out, plan to use them Cotten. I’m just glad I was able locate them and confirm they are correct. It’s great that folks like you are contributors to this forum.
            Jim
