panhead dual exhaust
  • jorrow
    • Feb 2008
    • 347
    The parts book refers to a true dual exhaust system for 54-57 but shows no actual photo of the right sided pipe that would replace the non-straight Y-pipe. I assume it would look similar but without the hole for the rear header pipe. Gasbox does not make this pipe. Does anyone have a picture of 65443-54?
    • 8247
    "Non-straight Y-pipe" confuses me, Jeff,...
    ...But I think you might mean this pipe:
    It replaces 65493-48; It is distinquished from repops by its welded construction, and conformity to a tin primary rather than aluminum.
    They ain't common.
    • jorrow
      • Feb 2008
      • 347
      No I've got that pipe Tom. Was referring to the right side piece that would now replace the Y-pipe on a dual exhaust set up. The more I think about it, there must have been an entire kit, because the mufflers would each be set further back towards the rear, as on a duo glide. But on a '57 there is the rigid frame factor, as there were no muffler supports on both sides. So the entire thing is rather confusing and would lead me to suspect I would have to invent all kinds of hangers. Im not sure if I want to go that route unless I can get a look at the actual kit that I can replicate. Thanks for the pic. Jorrow
        • 8247
        I just used a straight piece 'o pipe, Jeff!
        But even that is probably scarce anymore.
        Trashed exhaust pipes don't litter the meets like they used to...
