Spark control tab, 1950 Pan
  • Dablaze
    • Apr 2011
    • 157
    Hey guys. Not one of my frames has a spark control tab. I got one from Wesco for my 1950 Pan frame and was hoping some could post pics, suggestions measurements on where exactly I need to glue this to the frame. Maybe ideas on where the factory welds are too, ie front and back, just tacked, welded all the way around…Palmer’s book doesn’t have much that helps on this in particular.
    Everything helps!
    Craig
  • ronniecox
    • Feb 2013
    • 27
    sir, try looking at a duo glide frame but as far as i can remember there is no tab on a ridged frame
    • ronniecox
      • Feb 2013
      • 27
      the only one is up top next to the neck on the left side or bolted to the cases under relay
        • 4791
        The tab does not appear on wishbone frames. They used a variety of clamp on brackets for cable mounting.
        • larry
          • May 2009
          • 247
          So which frames did have that tab?
            • 4791
            Sorry, my bad. I was thinking throttle not spark. It should be on the left side of the neck at the leg connection on all the '49- mid '54 frames.
            • BEK
              • Dec 2003
              • 75
              The red one is an old original '55, the green one is a '52.
              Bruce Keith
              AMCA #1467
                • 4791
                All the info with pics is in Bruce Palmer's books.
                • Dablaze
                  • Apr 2011
                  • 157
                  Thanks guys,
                  I saw the images in Palmer’s but he questioned the placement saying “seemed high” (actually I didn’t know about this tab before goi g over the pics in Palmer’s) not that I might not have missed it…
                  The green one above is the best pic I’ve seen yet? Thanks BEK. Rubone your directions are always invaluable.
                  Craig
                  • Dablaze
                    • Apr 2011
                    • 157
                    Lol, I had one in a box from Wasco, brought it to the shop which is obviously a portal to never never land. Now I have to order another tab from Wasco, this frame is becoming a career, lol. Still, very happy with how it’s going, just slow in amongst other work.
                    Craig
