Factory replacement case questions
  • Panhead_Bobber_11C
    • Apr 2021
    • 67
    I got a motor here im looking to buy. The numbers and documentation look good to me only thing that through me off was the belly numbers. The bike is a 55FLH and the belly numbers are 60 4770. He told me they are factory replacement cases. And an old timer that's been doing this for a long time had told me that they did this. If you blew up your bike back then they would get new cases from the factory and stamp your vin number back on so in this case he says the motor blew in 1960 and they issued these. It is registered as a harley with the same numbers also. I posted pics for reference so from what he told me he blew the bike up in 1960 and got the cases replaced. With the original vin stamped in it. What do you guys think?
    • 4791
    Factory replacement cases were indeed available. But the factory did not stamp them, dealers did, so the numbers never match the correct font, the cases never match the correct version, etc. So despite it being legal, it is never as it was originally so can never be restored/judged/correct for the year model.
    • Speeding Big Twin
      • Mar 2010
      • 441
      How is your other bike progressing?
      Eric
      I got an OEM 54 straight leg frame for my 55 FLH motor recently. I just went to drop my engine in the new frame today and go to bolt it in. The problem that I'm having is when I put the 2 rear bolts in they line up fine and fit, then I go to put the 2 front bolts in and they are off by a c*nt hair. I tried the other way around
      • kitabel
        • Sep 2018
        • 471
        The 1960 right case is different, some of the original 1955 parts won't work..
        The 1960 uses a different pinion shaft and gears, a larger pinion bearing, and a needle cam bearing.
        The Linkert Book
        • Speeding Big Twin
          • Mar 2010
          • 441
          Is anything stamped on top of the cases near the rear engine mounting bolts? And if so, is it mentioned on the original documentation? Thanks.
          Eric
          • Speeding Big Twin
            • Mar 2010
            • 441
            On top of the cases at the rear.
            Eric
