motor oil...
  • Steve Galli
    • Nov 2019
    • 93
    motor oil...
    Is there a thread for what oil to run? Sure it’s been discussed a million times...
    Thanks all
  • Lyle Manheimer
    • Mar 2008
    • 193
    I have been using Valvoline VR1 20-50 conventional racing oil in my Pan for many years. Never a problem, lots of Zinc.
    • Rollo
      • Nov 2008
      • 599
      It has been beaten to death on here and elsewhere. I use Harley 60 wt cause the HD shop is less that a mile from my house and is about the same as comparable oils in price..
      Tom (Rollo( Hardy
      AMCA # 12766
      • craig (DE)
        • Oct 2010
        • 344
        What Tom said......
        Craig (Delaware)
        Delaware Bay Chapter
        Perkiomen Chapter
        AMCA Member #1011
        • Steve Galli
          • Nov 2019
          • 93
          Thanks guys.... does HD still make a straight weight oil? Looked online and only saw muti weight oils...
          • HD48FL
            • Jan 2007
            • 138
            My local dealer carries straight 50W and 60W.
            • craig (DE)
              • Oct 2010
              • 344
              My dealer carries straight weight and so does my local independent bike shop.
              Craig (Delaware)
              Perkiomen Chapter
              AMCA Member #1011
              • kitabel
                • Sep 2018
                • 471
                H-D specifies straight weight ("W" does not mean weight) based on air temperature. 60 is correct if it never gets cold.
                The Linkert Book
                • HDSmitty
                  • Jul 2017
                  • 282
                  Kitabel, I have always understood the "W" to mean weight as I'm sure many others have also. Please enlighten us with the correct meaning, I know it's not referring to temperature but I think to flow rate. The weight meaning may come from heavy (higher number) object moving slower, and it just transferred to oil ? Thanks in advance. Smitty
