65 FLH original relay
  • hdhikaru
    • Feb 2010
    • 217
    I am still working on the 65. is this year correct original relay for the biike? no delco sign though.
    if original, where it should be installed on the bike? tks Shin
  • vph-d
    • 1088
    65s did not originally have a starter relay, however, many had a retro-fit relay kit installed. I don't think the relay pictured is part of the kit.
    VPH-D
      I believe it is a turn-signal flasher, Shin!
      I found one hidden in the headlamp nacelle.
      • hdhikaru
        • Feb 2010
        • 217
        VPH-D thanks! so,,, there is no starter reiay on 65.... what year the relay installed first? I saw it underneath of battery case on 69..
        what is the reason to put the starter relay on? to give more electric to solenoid?
        Cotten, thanks! I just checked the terminals .... it should be starter relay. please see attached pics,
        tks
        Shin
        • craig (DE)
          • Oct 2010
          • 344
          The starter relay was added in 1967 to eliminate all the amps going through those tiny wires and the starter button on the handlebar. Early FLH electric start had issues with melting the starter button and wires when cranking the starter for extended period of time.
          Craig (Delaware)
          Delaware Bay Chapter
          Perkiomen Chapter
          AMCA Member #1011
          • Omarttentmaker
            • Dec 2009
            • 322
            tks
            Shin
            If that is a starter relay, it's not the one used by H-D starting in '67. At least not for big twins. Also, when the relay first showed up, it could be retrofitted to '65 and '66, as the MoCo offered a kit with a bracket that was attached to the underside of the battery box. Not sure exactly when, but you did not need the kit from '68 up as the battery box was, by then, made with a bracket as part of the whole weldment/stamping. If you bought the retrofit kit, you would have to drill 2 holes in the bracket in the "floor" of the battery box to attach the bracket and the relay.
            • gitguy
              Middle-of-the-road Member
              • Nov 2009
              • 254
              Although this is a repop it looks like this:
              • hdhikaru
                • Feb 2010
                • 217
                great!! than you guys!!
                • panz4ever
                  • Mar 2009
                  • 198
                  Herz a pic of an original one mounted on my 65 FLH (bracket is homemade).
                  The service bulletin
                  One more thing to consider
                  As stated neither was offered for 1965 models, both were available as add-on components. I have added both.
                  • craig (DE)
                    • Oct 2010
                    • 344
                    image_27500.png My original relay with homemade bracket too. Now if I can only figure out how to post a picture in the body of the message.....
                    Craig (Delaware)
                    Perkiomen Chapter
                    AMCA Member #1011
                    • 55tmm
                      • Dec 2009
                      • 158
                      Here is a picture of mine, and I wanted to practice posting a picture
                      This gallery has 1 photos.
                        There is a NOS relay on eBay now.
                          So what would an OEM flasher relay look like, folks?
                          Got my hopes up; Thanks in advance,
