1948 EL Front Header Pipe Clamp(s)
  • gitguy
    Middle-of-the-road Member
    • Nov 2009
    • 254
    Trying to determine the correct set up mounting the front header pipe on my 48 project. Parts manual shows 655121-37 as the only clamp but many other online sources refer to the two clamp setup seen in the attached photo. From what I can tell the two clamp arrangement was introduced with the swing arm in 1958 therefore making the single clamp correctfor rigid frame applications.
    Can anyone enlighten me?
  • panz4ever
    • Mar 2009
    • 198
    Parts book doesn't show it but it is my understanding that the front header pipe uses the 2-piece clamp.
    • gitguy
      • Nov 2009
      • 254
      Palmer discusses this s bit and he seems uncertain cuz this is another 48 oddball one year deal, I suspect. Thanks for chiming in. Two clamp arrangement it is.
