Electra Glide Pilot Lamp Wiring
  • craig (DE)
    • Oct 2010
    • 344
    Hello, I finally found a set of turn signal pilot lamps for my 65' Electra Glide. I have been trying to find the wiring diagram as to where and how these lamps get wired. Can someone shed some light on how to correctly wire these lamps?
    Craig (Delaware)
    Delaware Bay Chapter
    Perkiomen Chapter
    AMCA Member #1011
  • Omarttentmaker
    • Dec 2009
    • 322
    It's in the wiring diagram in the manual, Craig. If not in the '65 wiring diagram, it is for sure in the '68-'69 diagram. The difference would be that in '68 the pilot lamps were in the dash. I'm sure if you follow the diagram, but start from the lamps in the nacelle on your bike, it'll be a piece of cake to figure out where they hook up at the panel behind the nacelle.
    • craig (DE)
      • Oct 2010
      • 344
      Hi Otto, my '65 wiring diagram does not show the pilot lamps. I will look in the '68 diagram.
      Craig (Delaware)
      Perkiomen Chapter
      AMCA Member #1011
      • gitguy
        Middle-of-the-road Member
        • Nov 2009
        • 254
        I do believe it's in the 67 wiring diagram. Had this same issue years ago with my 66.
        • jorrow
          • Feb 2008
          • 347
          Just hook them to the same post that goes to each turn signal.
