Battery Needed for 65' Electra Glide
  • craig (DE)
    • Oct 2010
    • 344
    Hello, I need to replace the battery that came with my 65' which I believe was not the correct size or type of battery. My battery cable ends are straight and not the "dog ear" type. Can someone tell me the correct battery size and type that should be in my bike? Thanks!
    Craig (Delaware)
    Delaware Bay Chapter
    Perkiomen Chapter
    AMCA Member #1011
  • Architect
    • Dec 2014
    • 283
    This is the battery I am running in my '70 FLH, I know some others running the same unit:
    The Scorpion YIX28L is an AGM battery that replaces the YHD-12 and 6607-84 Harley Davidson batteries. Features 370 CCA and a 1-Year warranty!
    Same size as stock, works perfectly with stock cables and covers. I have had it for two or three seasons, no issues starts my stroked 80" shovel right up every time.
    • craig (DE)
      • Oct 2010
      • 344
      I've heard good things about Scorpion batteries. My cable ends are straight so I would have to bend them 90° to make this battery work. Thanks!
      Craig (Delaware)
      Perkiomen Chapter
      AMCA Member #1011
      • K. Felt
        • Mar 2014
        • 42
        Been using the battery Architect mentioned for many years. The side that shows (if you are not using a side cover) has a rectangle embossed on it. Looks pretty good. Straight cable ends should not be a problem unless they are too short. Here is a pic.
        • craig (DE)
          • Oct 2010
          • 344
          Thanks K.! I will check my cables to see how much play I have to mount flat.
          Great looking Pan too!
          Craig (Delaware)
          Perkiomen Chapter
          AMCA Member #1011
          • craig (DE)
            • Oct 2010
            • 344
            Just ordered the battery from BatteryStuff.com.
            Craig (Delaware)
            Perkiomen Chapter
            AMCA Member #1011
            • sswaney
              • 303
              I made a copper buss with a 90 degree bend to attach the cable on the positive lug. Solves the major cable problem too.
              • sswaney
                • 303
                I hate spell checkers. Not sure how short became major in the previous post?
                • craig (DE)
                  • Oct 2010
                  • 344
                  I'll see how much room I have once the battery gets to my place. I also have a circuit breaker attached to my positive post terminal.
                  Craig (Delaware)
                  Perkiomen Chapter
                  AMCA Member #1011
                  • jim wagnon
                    • Dec 2021
                    • 137
                    Great info. on the AGM battery! Just ordered one myself.
                    Jim
