dry cell pan battery ? 12v
  • flthead
    need a battery for my 65 pan ,looking for dry cell 12volt , anybody have info ?
  • D. N.
    Battery
    I changed over to 12volt on my 56pan. Went with Cycle Electric 12volt generator, & YUASA YTZ 14S it's the same battery used in the Hayabusa, also maintence free. Fits right in oil tank, need to cut a wood spacer because the battery is a little short, the stock cover works too. Put the negitive teminal down. And no more acid!!!
    • flthead
      65 pan battery
      65 pan battery is like tractor battery or early shovels ,doesnt sit in oil tank . thanks anyway
      • D. N.
        I knew that . Guess I just had a senior moment .
