dry cell pan battery ? 12v
  • dry cell pan battery ? 12v
    need a battery for my 65 pan ,looking for dry cell 12volt , anybody have info ?
    Battery
    I changed over to 12volt on my 56pan. Went with Cycle Electric 12volt generator, & YUASA YTZ 14S it's the same battery used in the Hayabusa, also maintence free. Fits right in oil tank, need to cut a wood spacer because the battery is a little short, the stock cover works too. Put the negitive teminal down. And no more acid!!!
      65 pan battery
      65 pan battery is like tractor battery or early shovels ,doesnt sit in oil tank . thanks anyway
        I knew that . Guess I just had a senior moment .
