Oil Pump check valve
  • KNUCK
    • 828
    Originally posted by lrcormier View Post
    I know it might look ugly, but could installing a small shut off valve in the oil supply line work? The danger would be if you forgot to turn it on prior to starting your bike, but has anyone tried this?
    Yes it will work, I run this on my WR so part of my morning start up is turn on the gas and oil valve for the day. Then at night when done riding gas and oil are turned off. It sits for weeks or months and no issue.
    • jim d
      • Sep 2010
      • 283
      Tom when I clicked onto the live link that you put up I also got the 403 error message . But if you go to the bottom of that page you can click on the homepage and it will take you there and then search oil valve shutoff. Thanks for putting it up.
      Jim D
      • lrcormier
        • Aug 2010
        • 142
        Thanks for your reply KNUCK. I'm still in the process of building (I say building because I got it in pieces) and hope to have it running by next spring. I suppose I could be one of the few lucky ones that their bike doesn't sump but not counting on it. If it sumps then a ball valve will be my solution and have found many possible candidates but not sure what size I'll need. Do you know what size you have or what size hose you used. My build is a 52 PAN and will be mostly stock.
        • Schorsch
          • Feb 2009
          • 91
          Thank you all for the discussion, decided to start the Motor every month during the time of no riding Season... George
            • 8248
            Please beware, George,..
            Motors are designed to operate under load; Please don't start it unless you're gonna ride it.
            Whether idling, or worse yet, "rapped" as if to warm it up, wear is much worse upon the assembly than 'full-tilt' high-speed highway cruising.
            If you set the jug o' oil on the footboard, you won't forget it.
            • Schorsch
              • Feb 2009
              • 91
              Hi T.Cotten,
              on the other hand, to start the motor with the crankcase full of oil, is a really bad action, it could destroy the motor!
              Normally you have to drain the crankcase prior to start the motor. But that drain plug is so bad placed between the
              frame and the crankcase...
              George
                • 8248
                Hi T.Cotten,
                George
                If you drain the tank into a jug, George,..
                There won't be enough oil to fill the cases.
                PS: The only way cases can fill to a dangerous level is when a positive seal has been installed upon the sprocket shaft, usually to accomodate a belt.
                Otherwise, the oil can fill no higher than the sprocket shaft, as the 'slinger' is an escape to the primary.
                • Schorsch
                  • Feb 2009
                  • 91
                  Hi T.Cotten,
                  yes, I agree , an empty oil tank during the "no riding season" should be the easier solution,
                  because an oil level into the crankcase up to the sprocket shaft level is too much and dangerous
                  to start the motor…
                  George
                    • 8248
                    ...because an oil level into the crankcase up to the sprocket shaft level is too much and dangerous
                    to start the motor…
                    George
                    No it ain't, George!
                    Sure it can be messy, or foul plugs,
                    But horror stories of the rear jug lifted off the deck usually included extraneous factors, like somebody's 'better idea' seal, etc.,..
                    ...and don't forget a loose nut on the handlebars.
