48 Panhead air cleaner cover attachment - easy question!
  • harleygreg
    • Oct 2018
    • 215
    Hi guys
    I’m not sure how the spring steel and the mesh fit together to provide the tension for the cover on the j-slots?
    Do the ends of the spring steel fit into the slots in the mesh support, or does it just ‘sit’ in the mesh support and the cover provides the compression to expand the spring so it doesn’t move?
    Greg82AD0BAD-6633-4810-855D-EEB7BCC20D28.jpg 71D9FA0D-FD1A-4982-BEBD-6A6F393804B6.jpg
  • Architect
    • Dec 2014
    • 283
    Second picture, hooked into the slots is how I run mine.
    • Rollo
      • Nov 2008
      • 599
      The spring steel hooks into the mesh filter and put pressure in the cover from the inside to keep it from backing out of the j hooks slots.
      Tom (Rollo) Hardy
      AMCA #12766
