'48 Panhead - inner chainguard rear spring attachment
  • '48 Panhead - inner chainguard rear spring attachment
    Hi Guys
    The Inner chainguard is attached at the upper rear by a nut and bolt and spring etc. The three frame components are; inner crankcase, oil tank, and chainguard. In what order, inside to outside, are these fitted and is the enclosed photo the right way to connect? I'm assuming the spring is there to allow some flexing of the inner chain guard?
    Is the lower rear fitting the same, in that the spring is located between the inner chain guard and the frame?
    Greg
    Here is how it is shown in the 1948 factory photo.
      Great picture, Chris. Also, thank you for the countless rare, and detailed pictures you have taken the time and effort to post and share with us over the years.
        Thanks Guys, perfect
