Horn button wiring
  • lrcormier
    • Aug 2010
    • 142
    Horn button wiring
    According to the 48-54 wiring diagram there is only one wire coming from the horn button and I presume this would be to route the ground side to the horn. Does this work when you have rubber mounted handlebars? Or for that matter even with solid mounted handlebars it would still seem that the front end is electrically separated from the frame. I don't want to complete this assembly and find out later that I should really use two wires so that it can get a real frame ground.
    • 2024
    A single wire horn system sometimes struggles to find a ground thru the chassis under perfect conditions but with rubber
    mounted bars I would try to sneak a wire in there someplace to help.
    Jerry
    • lrcormier
      • Aug 2010
      • 142
      Jerry
      Thanks Jerry, I think to be safe I'll use a second wire to get a solid ground. An unreliable ground is probably why HD went to two wires after 54.
